sljkansas
Sep 24, 2014Explorer
Last year I used 2 25 foot heat tapes on a my 2 white hoses. I wrapped the heat tape around the hose an then covered it all with the black foam insulation tubes and taped around the foam. Temps got down to 5 degrees. I had water freeze at the hydrent . I found that I didn't wraps the heat properly at the hydrent. Re wrapped and all was good. So with the low temps you may face shouldn't get that bad.
