sljkansas
Sep 26, 2014Explorer
I believe it was frost king, but any one of them should work. The biggest problem you run into is not wrapping the heat tape tight enough to transfer the heat. Make sure you use either foam or foiled fiberglass wrap around the hose and tape. Another thing I did was to put a large plastic trash can over the water supply to help keep it warm, and make sure the heat tape is well wrapped around the hydrent tightly, that's where I made the first mistake, the water froze where the hose screwed to the hydrent.
