DABZ's avatar
DABZ
Frozen fresh water tank
My fresh water tank froze up. I had a heat gun for 30 mins to valve to empty tank just to open it and found frozen water all the way up. Not sure how far in it is. Any suggestions on unfreezing while RV is outside in freezing weather? I was hoping to unfreeze it to prevent further damage since winter is just starting.
❚ Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
  • Today's weather in Naples, Florida, has a high of 80 and a low of 65. That should melt the ice. See https://www.bing.com/search?q=weather+naples%2C+fl&form=EDGTCT&qs=PF&cvid=a9b440202a5c487b8f8b68d755ba744c&cc=US&setlang=en-US
  • Four season coaches have insulated tanks. You can insulate the bottom of your RV is you don't have one.
Having RV issues? Connect with others who have been in your shoes.24,273 PostsLatest Activity: Jun 24, 2025
