Twomed
Oct 08, 2018Explorer
Onan 10k Parts
Fuel Filter NAPA 3063
Oil Filter
NAPA 1307
Air Filter NAPA 6449
Fuel Pump Amazon Airtex E11020
Cummins Onan # 187-1289 glow plugs are $49 each, and NGK # 5392 Y720U are $10 each from Rock Auto… you need three.
Fuel filter is locate din the side access door down low and to the right, silver in color. Two 10mm bolts on the outside of case will release the filter bracket and you can lift the whole assembly out and change the filter. Pay attention to orientation of the two fuel lines and the whole thing pops right back in...misalign the connections and you will be using wordy dords!! Easy after the first time.
Part # above will save you a bunch of $$
Oil Filter
NAPA 1307
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
