DeniseRV's avatar
DeniseRV
Fuel Gauge stuck on full
On our 2002 Fleetwood Southwind 32VS, F53 chassis, the fuel gauge always shows full, except when engine is turned off. With engine off, needle goes to empty. RV runs/operates fine otherwise. This just started happening after using the RV for 2 1/2 years (purchased it in 2016). Looking at the chassis doc, there do not appear to be any fuses associated with the gauge. We found no loose wires under the dash but cannot access the area directly under the gauge. Any advice on how to fix this or ideas on where to start troubleshooting? I did see an online post that we should check the sender wires. Would those be on the fuel tank? I'm guessing we would have to crawl under the rear section and try to find the wires somewhere on the fuel tank? Does anyone have pictures/diagrams that would help? I am not a mechanic at all, so apologies for any dumb questions... also this is my first post since joining rv.net. Thanks in advance for any help fellow members can provide.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
