Still having problems trying to figure out why electronic fuel pump is not pumping all the time! I have found what appears to be an oil pressure sensor/ fuel pump cut off switch! There is power going ...
I wrote in your other thread that the fuel pump replay is a common failure item and is replaced when ever the pump is. Relays are cheap. So just replace it as a precaution.
