kioticoachman
Jul 24, 2021Explorer
RLS7201 wrote:
When you push the prime button, do you hear the pump? Is there voltage to the pump? If you can hear the pump, attach a short hose to the inlet and see if the pump will suck gas from a gas can.
Did you remove the filter and try to blow through it?
Your post indicates that you are just trying to throw $$ at your generator instead of trouble shooting the problem.
Richard
I should have been more specific. The generator has a stop-prime & start button on the exterior of the unit. When the stop-prime button is/was pushed with the gas line disconnected from the carburetor you do not hear the pump and there is no gas being pumped from the line to carburetor. Hope this helps? CC
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
