j-d
Aug 24, 2015Explorer II
I think I've got the gist of this. The 454 has a carburetor fed by an engine-mounted mechanical fuel pump. BUT SOME P-30 models have an in-tank electric pump feeding the mechanical pump. OK so far? The electric pump is powered through a relay. The relay powers the pump IF either, driver is cranking the engine, OR the engine is running, determined by oil pressure.
OP believes the in-tank pump isn't running due to a bad relay or not staying running due to an intermittent relay.
A likely scenario, but... Are all filters new or clean, including the little one in the inlet of the Quadrajet? And, is the mechanical pump good?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
