tealboy's avatar
tealboy
Fuel shutoff switch for Honda eu
I did not have my reading glasses on when I originally posted my question related to this topic so my apologies. But I’m trying to determine yes, what is the advantage over this aftermarket switch that can be added to the Honda EU 2000 that allows you to shut the fuel off while the engine continues to run so we can burn all the fuel out of the carburetor versus simply unscrewing the screw at the bottom of the float bowl and letting the fuel run out. I always drain the fuel and suspect the switch is essentially doing the same thing just more conveniently then having to unscrew the drain on the carburetor so it would be a convenience more than anything, right?
  • I disconnected the spark plug ground from the ON/OFF switch. Now, when I turn off my Honda, it shuts off the gas, but runs till the carb runs out of gas. I guess I should check and see if any more would come out of the carburetor.
    Does turning it off then draining the carb of gas also get the gas out of the small channels in the carb? Does letting the generator run till it runs out of gas pull the gas out of those small channels?
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
