tealboy's avatar
tealboy
Fuel shutoff switch for Honda eu
I did not have my reading glasses on when I originally posted my question related to this topic so my apologies. But I’m trying to determine yes, what is the advantage over this aftermarket switch that can be added to the Honda EU 2000 that allows you to shut the fuel off while the engine continues to run so we can burn all the fuel out of the carburetor versus simply unscrewing the screw at the bottom of the float bowl and letting the fuel run out. I always drain the fuel and suspect the switch is essentially doing the same thing just more conveniently then having to unscrew the drain on the carburetor so it would be a convenience more than anything, right?
  • With the factory fuel shutoff/kill switch you can unplug the kill switch portion and it will function as just a fuel shut off but you will not be able to just shut it off without adding a switch. Will work fine if you always want to run out all the fuel. For a couple of bucks you can add a momentary switch to the wire that needs to be unplug from the fuel shutoff
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
