mike-s
Sep 28, 2016Explorer II
westend wrote:I don't think he's planning on connecting the circuits for both heaters to the new tandem.
Not at all. The OP wishes to run two heaters with a 50 amp service. He wishes to balance the loads between the two legs of his 50 amp service.
If the tandem breaker or two single breakers only attach to one leg of his 50 amp service, he is not balancing the load between the two legs.
He wants to move the circuit supporting one of the heaters to the other leg. To do that, he can replace an existing full size breaker on that other leg with a tandem, and reconnect the exiting load to one side of the tandem. He can then connect the heater circuit he wants to move to the other side of the tandem. Done - he has the heaters on different legs.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
