ScottG
Sep 28, 2016Nomad
mike-s wrote:ScottG wrote:It may matter. As he said in his original post - "better for when I'm running my generator." He may have a split-phase gen set.
A tandem breaker will work just fine for the OP. There is no need to run a space heater off each leg. It just doesnt matter.
And that's what I said in another post. If there's a generator or inverter involved then loading matters.
Otherwise, again like I said before, as long as you don't exceed specs it just doesn't matter.
That situation aside, in a case where the micro, and a couple of other large loads are involved it still doesn't matter because there is plenty of current avail. - as long as you don't exceed specs.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
