Stefonius
Sep 28, 2016Explorer
joebedford wrote:Sorry... I thought you were talking about a 240v double breaker. You should have no trouble using a tandem breaker, but be aware that it will be pulling current from only one leg.Stefonius wrote:I only have one slot available so I can't add two breakers.
If you're running "one heater on each leg", you should use two single breakers rather than a tandem. You can easily make sure each breaker is on a different leg.If you're using a tandem breaker with two potentially unbalanced 110v loads, you can cause problems.I don't understand this - please explain.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
