DougE wrote:
I have CarMD and it didn't pick up any codes so I'm also working up the food chain to something better. I do have a couple of shops I trust to do the check but if there's a reasonably priced reader ($100+/-) out there that would do the job I'd probably upgrade to it.
have a scanguageII, sold as a mpg and other data display that also reads thrown codes or pending codes. Also for different vehicles it can query for other data.
However, while I've used it to pull codes for myself and others on a wide variety of vehicles and always had it give the data needed, I don't know if it will pull airbag related codes for you.
Not as good as the SW based tool I also use, but if you know someone that has one you can give it a try.
