CA_Traveler
May 01, 2023Explorer III
120V devices take a lot of power and you have a small solar battery setup. For example a 10A A/C would require the inverter to draw 100A from the battery, hence you have 2 hours of run time plus a few minutes if the sun is out.
You could save a little but it's very dependent on your AC device usage and DC usage.
Your charger and solar controller don't trump each other. Each contributes to the house loads and any remaining power charges the battery.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
