Almot
Jun 01, 2021Explorer III
Update with more sun and 2*100W in series.
June 1, 7.30am, battery resting 12.8V.
Clear sky, panel V=35, current 9.3A, load 2.7A.
Disconnected the load, current dropped to 8.5A, i.e. 0.8A decrease.
(Effect is similar to yesterday's single-panel conditions when current dropped by 0.7A from 1.4 to 0.7 after disconnecting 2.5A load).
Note that 9A is 60% of theoretical maximum power of 200W array post-controller, so not a bad solar day.
Haze, panel V=30, current 4.5A, load 4.2A.
Disconnected the load, current dropped to 3.2A, i.e. 1.3A decrease.
(Effect is different from yesterday's single-panel conditions but not much different: yesterday current dropped by 0.5A from 5A to 4.5A after disconnecting 4.5A load).
It should not be doing this, not with LFP battery, this is not a Float, the battery is far from being full. I am losing more than 10% of available energy.
I think this controller has a poor charging algorithm and/or poor firmware. Adding one more panel should help the bottom line but this effect of demand will likely still be there.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
