Gdetrailer
Mar 04, 2022Explorer III
time2roll wrote:
My OEM ducting was inadequate. I added 2x 4" additional ducts and the furnace works so much better with tons more heat and the burner stays on the entire cycle.
I believe OP has had this RV for a while and this IS a recently new "symptom".. If I am correct, that would make the assumption of not enough ducting not much of an issue unless a new blockage has been introduced (like a blanket covering a register?)..
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
