Rmack1's avatar
Rmack1
Furnace anticipator
I had the control board on my furnace replaced, which fixed it, but before that I tried a new thermostat.
The new one, like the old, had an adjustable anticipator. This is a little dial on the inside of the thermostat that adjusts the amps, or something. The manual said to set the thermostat anticiptor to .7 amps, which I did.
The thing is; my furnace now goes on and off several times sometimes before settling down and running. I tried adjusting the anticipator .05 amps at a time, like the manual says, to .8 and .6, but all settings seem to produce a stutter before the furnace decides to stay on.
Should I just try further settings on the anticipator?
  • Get this;
    I just set the anticipator to .8 and it seems to be running fine now.
    I think I was being too conservative, and didn't fully set it to .8, and .79 didn't cut it.
    Forehead slap.
  • If it's a Energy Star rated stat, that's pretty much what they do.
  • Normal setting is .8
    Furnace should run about 6 times per hour. Increasing the number reduces the runs.
    Make and model of furnace?
    Make and model of thermostat? Is it set for gas operation?
  • btw, the anticipator settings are suppose to lengthen the time the funace cycles between on and off if you increase it, and shorten the time if you dial it down.
