Old-Biscuit
Sep 25, 2017Explorer III
OP...you have enough discharge ducts.
How is airflow from each register...lacking could be sign of collapsed duct
How is return airflow. Nothing stacked up next to furnace OR obstructing return air??
Check exhaust ......obstructed will cause heat build up (mud dabbers. nests)
Propane pressure.
Turn ALL stove top burners on HIGH one at time.'
Do flames recovery quickly when another is lit?
Are all flames same....height/color?
With flames on ....turn furnace on.
Get same short cycling?
Do stove top flames diminish or stay steady?
Propane pressure.
