chinook507ExplorerNov 03, 2019Furnace CyclesHave a 2013 Cougar 32RBK Xlite and the furnace burner cycles on and off while the blower continues to run until the set thermostat temperature is reached. Was wondering if this is normal?
Chris_BryantExplorer IINov 03, 2019No, it isn’t. Check the ducting for blockages or recirculating hot air. It is never good for it to cycle on the limit switch.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
Related ContentFurnace Short-CyclingFurnace short cyclingQuestion about Furnace Short Cycling..Furnace flames cycles off before temp is reachedFurnace cycling strangely
