Have a 2013 Cougar 32RBK Xlite and the furnace burner cycles on and off while the blower continues to run until the set thermostat temperature is reached. Was wondering if this is normal?
Not normal. The existing ducts are either inadequate or blocked from debris or poor installation.
Mine was poorly installed to minimum spec with joints blocking air flow and floor insulation collapsing the duct. I ended up adding two additional ducts using the 4" knockouts. Tons of heat now and burner runs until the thermostat is happy.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
