Have a 2013 Cougar 32RBK Xlite and the furnace burner cycles on and off while the blower continues to run until the set thermostat temperature is reached. Was wondering if this is normal?
“Normal. Ours does that so that it doesn't overheat when running for longer periods of time. Safety feature of the furnace.”
Circuit breakers are a safety feature, but if you are relying on a breaker to pop every five minutes you are relying on the last layer of protection, and are not safe. What happens when the contacts of the over temperature switch weld themselves together from excessive cycling?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
