chinook507ExplorerNov 03, 2019Furnace CyclesHave a 2013 Cougar 32RBK Xlite and the furnace burner cycles on and off while the blower continues to run until the set thermostat temperature is reached. Was wondering if this is normal?
joebedfordNomad IIINov 04, 2019The Atwood manual says: fix the ducting, replace the limit switch, adjust LP pressure.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
Related ContentFurnace Short-CyclingFurnace short cyclingQuestion about Furnace Short Cycling..Furnace flames cycles off before temp is reachedFurnace cycling strangely
