John_Wayne
Nov 24, 2013Explorer II
Dose it do it only when you turn it on after not using it for a while ( few days to weeks) but then works well after it's been used. If so it's like mine and air is in the propane pipe. Mine will try and light 3 times and I can hear the flame but then the flame stops. I have to turn off the thermostat as many as 3 times before it will keep going. This will happen even if I've started all the stove burners to clear the propane lines.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
