troubledwaters wrote: Thermostat set to the fan on function?
RV furnace fan is NOT controlled by the wall tstat Fan setting. The usual cause of this is the Hi limit switch stuck closed. Another long shot would be water corrosion on the furnace circuit board fusing the fan relay. Doug
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
