I have been living in my RV for a couple of months now and seems that I have spent more than I should have on propane. I typically fill my two 30lbs tanks and two 17lbs BBQ tanks. I know that with a...
UGL the amount of LP you are using IS NORMAL you can switch to a catalytic heater to use less LP or you can switch to portable electric heat or you can turn down the thermostat on demand is NO more efficient during use than a regular tank style heater it does give a steady supply and if you like long showers (the biggest benefit), you will use more propane turn of the WH when not using it
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
