I have been living in my RV for a couple of months now and seems that I have spent more than I should have on propane. I typically fill my two 30lbs tanks and two 17lbs BBQ tanks. I know that with a...
X2 MrWiz, your usage is normal. Like was mentioned, turn down the furnace at night and use an electric blanket. Also, turn it down during the day when you're not at home. If the insulation in your rig is really good, turn it on in the morning, let it cycle once or twice then turn it off. Yeah, the temps will drop in the rig but you'll use less propane. Maintaining the temperature does NOT save propane. Not running the furnace saves propane.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
