I have a hydroflame 79/80 in my 1996 Lance 11.5. It worked great last year before I unlocked her for the winter. I just put it back on and off course New England is not going to let go of cold nigh...
A sail switch is located near the squirrel cage. When the cage rotates the airflow causes a little sail like arm on the switch to move and close the switch. When the switch is closed the gas valve is then allowed to open provided all else is well. I think the service manual for your furnace is located at
http://bryantrv.com/docs2/docs/hydroflameold2. If not look through http://bryantrv.com/docs.html and see if the right one is listed
