I have a hydroflame 79/80 in my 1996 Lance 11.5. It worked great last year before I unlocked her for the winter. I just put it back on and off course New England is not going to let go of cold nigh...
I'm going to jump the gun and give you a cheap and easy fix. The reason why is because my neighbor had your setup and after pulling the furnace and going through all the systems it turned out to be this.
Pull the cover off the furnace and you should see the high tension wire. Gently pull that off the sparker and clean the connection. See if that fixes your problems. Could be the Achilles heel of that model.
