My furnace (1995 Dutchmen) was blowing cold air when the heater was set to 90. I went and unplugged two wires on the furnace and heard the igniter turn on and it started working. Think there's a short...
All you did was to reset the circuit board- when you unplugged the motor, the sail switch opened, then closed again when you plugged it back in.You could do the same thing by shutting the thermostat down, then back up. Look at the far left side, unplug the edge connector on the circuit board and plug it back in a couple of times. I second the thermostat suggestion- *if* the thermostat only controls the furnace, or if it is an old Coleman mechanical thermostat.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
