oldgreyExplorerFeb 11, 2019furnace leakhoping someone could help me out here. so I basically live in my rv up in alberta Canada, -25c usually in the winter...just as of late when my furnace kicks in I get a strong exhaust smell inside the ...Show More
wa8yxmExplorer IIIFeb 12, 2019Sounds like two problems1: Not blowing out so much.. can indicate a bird or insect nest in the path of the heat/exhaust flow. BUT..2: Strong smell inside: Heat excchanger is damaged and needs to be replaced.. NOTE this will also fix #1.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
Related ContentLippert faucet leaks, replaced with MoenOverhead Cab Leak on 2005 Winnie MinnieWater Heater Leak on start up.FurnaceFurnace Troubleshooting
