charlesdennis01
Nov 03, 2017Explorer
charlesdennis01 wrote:enblethen wrote:I took a picture of the sticker on the furnace and is model AFMD25121_ _ A is made by Atwood hydro flame
Did you try spinning the fan by hand?
Look for a small time delay relay mounted on the fan housing. Inspect it for black burnt area.
Verify 12 volts DC to relay
Do you have exact make and model?
I took the panel off from under the fridge and getting the process started to get the furnace out, I don't have and outside panel to access so have to do it the hard way. Do I have to unscrew the small vent outside first or can I pull the furnace with having to remove the small vent outside
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
