jornvango's avatar
jornvango
Explorer II
Sep 15, 2017
Furnace not working
After a long and hot summer, we camped in the mountains last week and wanted to turn on our furnace heater at night. The thermostat clicked but the furnace didn't turn on: the fan didn't start.
Other gas appliances like the fridge and stove work fine on 12V.
I used a multimeter to check all fuses but all seem to be ok. There is no labeling so I don't know which fuse is for the furnace.
Before I call an RV mechanic to come out, is there something else you recommend I check to troubleshoot?
Thank you, Jorn
  • Perhaps you reset the flame rollout switch. If so, you should probably verify the integrity of the heat exchanger.
  • No, the circuit breakers are normally a small push button.
    It could be a safety switch for when maintenance is being done.
  • I opened the interior furnace vent and noticed an Off / On-reset button. It was Off. I turned it on and the furnace works again.
    Any idea why this button would be Off? It requires a screw driver to open so it's definitely not something I turned Off. Perhaps an RV mechanic when he installed solar a few months ago for whatever reason?
    It's an Atwood furnace. Is this the circuit breaker mentioned in an comment above?
  • Have you tried using furnace when connected to shore power? Furnace fan won't start up if you have low batteries.
  • Ignitor will not "click" if the fan is not running. Fan must close sail switch before ignitor will work.
  • wiggle some wires on heater when you hear it clicking, might be just a loose wire.
    X2
  • Verify that the on/off switch on the thermostat is on. If equipped.
    Fan should start as soon as the thermostat calls for heat.
    Make and model of thermostat and furnace?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    You said the fan did not even start......
    On an Atwood furnace, of you go outside and remove the access cover you will see a switch atop the blower housing. it is really a circuit breaker, Cycle it.
    On the control board is an LED if it is flashing count the flashes and pattern and post.
  • My thoughts, On the surface of your post
    Fuses... OK
    T-stat...OK
    And Propane is making the trip to furnace?
    ...wiggle some wires on heater when you hear it clicking, might be just a loose wire.
    Then if no help...get out the manual and go through trouble shooting check list.
    Then RV mechanic
