rjsurfer's avatar
rjsurfer
Furnace pops breaker after 30 seconds.
My new Cougar has it's first problem, the furnace runs(gets hot)for 30 seconds or so then pops the 15 amp breaker.
It doesn't make a difference if I run on Auto or manual fan, same symptoms.
I'm thinking the fan sounds a little strange, but that could be my lousy old age hearing??
Any ideas....no time to bring it for warranty service we're off on a camping trip Sunday.
Ron W.
  • What do you mean by a "15 amp breaker"? Where is it located at the furnace or elsewhere? Usually "breaker" means 120v, so it is confusing. There are DC breakers though--resetting and those with buttons to reset them.
  • MEXICOWANDERER wrote:
    Mr Ron,
    Without hinting about volts and amps, you are opening the floodgate for 500 different opinions with a correct answer hiding like a needle in a haystack.
    Polite suggestion. It's new, right? Take it back to the dealer. Return home and pop a brewski. :)
    I will be taking it to the dealer but we're heading off for 10 days near Asheville first, no time for dealer trip.
    Ron W.
  • First of many suggestions:
    If the fan sounds strange, maybe it has interference or a dry/
    tight bearing causing it to pull more amps.
  • Mr Ron,
