0rionExplorerOct 11, 2014furnace questionI apologize for lack of model number. I didnt write it down before coming into the woods. I'm hunting with my son this weekend & woke up this morning to no heat. The blower kicks on but the ignitors n...Show More
DelphiExplorerOct 11, 2014If you have a generator with you, try starting the furnace while the generator is running.If it's the sail switch, that might give the blower enough power to get things started.Then you can try turning off the generator to see if the furnace continues to put out heat.Good luck!
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
Related ContentSuburban Furnace QuestionFurnace Questionfurnace/heater questionQuestion about Furnace Short Cycling..Furnace Lighting Question
