wnjj wrote:
First of all the fan switch is only for the A/C unit and does nothing for the heater.
If the heater fan runs for when you turn the heat on but doesn’t light, it’s either not getting propane, the igniter is bad the sail switch (which detects the fan running) is bad or the control board itself failed (less likely). Before all of that, is your battery fully charged or are you plugged into shore power (I assume so since you ran a space heater)? If the fan doesn’t run fast enough it will not attempt to light.
Also try lighting a stove burner first to be sure you have propane flowing and the most air purged that you can.
Is this a brand new unit or new to you?
To answer the basics. We were connected to 30amp service. We fully used the stove/oven, pilot was lit entire weekend. Furnace is under the stove so it should be getting propane.
The fan does kick on for the 30-60 seconds with airflow out the floor ducts and furnace exhaust.
