darsben
Oct 06, 2013Explorer II
duggram wrote:darsben wrote:
... must break the thermostat call for heat (see excerpt from manual below)...
Exactly how do you do that? I tried turning off the power to the trailer and disconnecting the battery. That didn't work. The furnace starts, puts out heat for about 10 minutes and then shuts down. The thermostat is set for 75 and the room temp is 70.
What that means is if you break the call for heat at the thermostat then the unit resets. You still have the underlying problem and it will happen again. The owners manual gives troubleshooting tips for this problem.
I cannot guide you further as I do not have the exact model you are dealing with but it usually means either dirty orfices or LP gas problem.
Check the manual
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
