wa8yxm
Oct 07, 2013Explorer III
You say it runs for five minutes, Do you mean the blower blows or the burner burns?
I have had a problem with my Attwood where it would start normally, the blower came on, a few seconds later the burner ignighted, things started warming up and then it shut down.
Turns out I had a bad control board (Replaced with a Dinosaur board and all is fine now) but a bad thermocouple in the burner housing or a bad connection between the two can do that too.
The board was failing to read the signal (0.480 volts) from the flame sensor (Thermocouple) and thought ignition had not occurred.
I think I know why this happens.. It appears to folks at Dinosaur boards agree with me as they protected against this specific failure. But hey... IT works now.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
