GSHenn's avatar
GSHenn
Furnace/fan & fridge won't fire
Ok,
After many hours, and finding a corroded ground wire, thinking converter was bad, I now have 12V coming into my travel trailer. I still don't have fridge/furnace or blower fan. Checked all the voltage coming from control panel on the fridge including the fuses. Everything good there. Still can't figure out what's going on!!! Ugggghhhhh!
  • Does anyone know what the circuit board on the back of the fridge controls? All outlets and fuses test ok but still nothing
  • All the fuses tested ok on the converter panel. The stove lights ok.
  • I have worked on more than one unit where the furnace and fridge shared the same 12 volt fuse at the converter. I'd start there.
    Good Luck
  • The only they have in commonis 12VDC and gas. It has to be one of the two.
