rrupert
Jan 05, 2021Explorer
I assume you have a converter/charger that is contained in the power center. Saying you looked at the fuses I assume you found it. Have you actually tested the fuses, sometimes they look good but are burned out? Depending on the trailer and how it was designed the furnace and the water heater could be sharing a fuse.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
