enblethen
Jan 05, 2021Nomad
You need to get a basic 12 volt DC test light.
Locate the power feed to the furnace and check for power.
If no power open the 12 volt DC fuse panel and verify that there is 12 volts leaving each of the fuses.
Are you plugged into shore power or just using battery? You said lights work. Are they bright or dim?
You may need to find a friend to help troubleshoot 12 volt power.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
