Old-Biscuit
Jan 05, 2021Explorer III
Furnace Fan MUST run before ANYTHING else can happen
Could be blown fuse in the DC Dist Panel.... one of those 15A fuses
Could be on/off cb switch on furnace that has tripped....manual reset
***Do you hear a CLICK AT thermostat when you set the temp higher then room temp and HEAT is selected????
Water Heater....
Could be Blown Fuse in the DC Dist Fuse Panel
The DC could be on same circuit as Furnace or another fuse
Check the 2a Fuse on Water heater circuit board in outside compartment (IF it is an Atwood ----Suburban circuit breaker is on backside of WH Tank and has no fuse)
What Brand/Model are the Furnace/Water Heater????
Water Heater....
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
