Boon_Docker
Feb 22, 2021Explorer III
Old-Biscuit wrote:schlep1967 wrote:
Both run off 12 volt. Is the battery charged and the battery cut-off switch turned on?
This^^^^
Propane is common but stove OK then DC Voltage is the other common component
***first time trying furnace/water in awhile......then could be propane flow
Might have to try each appliances several times to establish full flow/pressure at each one
That was more than likely the problem.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
