dougrainer
Jan 13, 2019Nomad
sgfrye wrote:dougrainer wrote:
Your Camera connection is NOT connected to the upper clearance light wires. You have connected to a wire that is 12 volt positive all the time. Doug
Yes thank you for confirmation. I thought this was what happened The factory worker on assembly connected the “prewired camera mount power supply wire “ to whatever he or she found. Great work. (Sarcastic) So far nothing else has shown up as assembly problems . Hopefully.....
Are you stating there was a wire in the top rear just for a Camera? If so, don't be too quick to blame the Factory. Some Trailers have a prewire but have a ON/OFF switch located somewhere up front either inside or outside. Remember, YOU installed and connected the Camera to the rear wire. Not the Factory. Doug
