sgfrye
Jan 13, 2019Explorer
dougrainer wrote:sgfrye wrote:dougrainer wrote:
Your Camera connection is NOT connected to the upper clearance light wires. You have connected to a wire that is 12 volt positive all the time. Doug
Yes thank you for confirmation. I thought this was what happened The factory worker on assembly connected the “prewired camera mount power supply wire “ to whatever he or she found. Great work. (Sarcastic) So far nothing else has shown up as assembly problems . Hopefully.....
Are you stating there was a wire in the top rear just for a Camera? If so, don't be too quick to blame the Factory. Some Trailers have a prewire but have a ON/OFF switch located somewhere up front either inside or outside. Remember, YOU installed and connected the Camera to the rear wire. Not the Factory. Doug
On this TT There is a camera bracket installed on rear exterior wall by factory with a camera power plug already installed for furrion cameras. I installed camera in bracket and plugged in camera. Only gets power plugged in to shore power. Previous TT had a wire installed in the bracket with no plug . Used camera female plug included with camera and I spliced into TT wire in bracket That wire was connected to marker lights. If there is an on/off switch I would love to find it.
