SJ-Chris
Jul 09, 2018Explorer II
I continue to learn..... I was reading up more and here's what I learned...
The wall switch is in fact just a remote switch that goes to a house battery disconnect solenoid located under the rear bed near the converter. Here (I believe) is a photo of that in my 2006 Four Winds RV:
When I push the battery disconnect switch by my side entry door, I believe I used to hear a "Click" noise. I assume that was coming from this solenoid. Well....now when I push the battery disconnect switch by my side entry door I do not hear any sound at all. I suppose it could be a bad disconnect switch, OR it could be a bad solenoid. Can anyone recommend how I can easily check the solenoid to see if it is working properly?
I found a replacement solenoid here if needed:
https://www.amazon.com/INTELLITEC-0100055000-Battery-Disconnect-Relay/dp/B072N8NYN2
Thanks!
Chris
Thanks!
Chris
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
