harold1946
Feb 01, 2017Explorer
They are counted from top to bottom in each row from the right.
1-open
2-horn relay 20A
3-dome and courtesy lamps 20A
4-adjustable throttle motor 10A
5-open
6-open
second row
7-body builder 20A
8-open
9-headlamp switch, park marker, and tail lamps 20A
10-turn signal switch, park and reverse relays 15A
11-open
12-body builder jacks alarm 5A
third row
13-cigarette lighter 20A
14-instrument cluster, body builder feed, backlighting switches 20A
15-DRL relay control module cluster, grade brake switch 10A
16-body builder, radio 15A
17-license lamps, marker lamps 10A
18-open
19-body builder radio 10A
fourth row row
20-open
21-cluster, tire check 5A
22-wipers 15A BRKR
23-front park lamps 5A
24-step alarm 5A
Right top- body builder 30A BRKR
Left top- body builder 30A BRKR
Some of the ones marked open may be used and some marked body builder. You would need to check with Fleetwood or the build sheet for any that were used.
1-open
2-horn relay 20A
5-open
6-open
second row
7-body builder 20A
8-open
11-open
third row
18-open
fourth row row
20-open
22-wipers 15A BRKR
24-step alarm 5A
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
