blueh20
Oct 29, 2018Explorer
red31, I dont have a purpose for the ml-acr, it was in the system when I bought the van, I am almost wondering, after all of these posts , maybe I should take it out of the van ?
You mentioned "backward wiring", I just re wired the system as the original owner had it wired, I drove the van around wired the original way for 3 months, all seemed to work well, kept the arb fridge at 34deg, seemed to work, so just put it back together the same way, while adding fuses/breakers/wiring etc.
"Will solar charging cause the backward wiring to combine the batts?"
I dont know the answer to that, I was told( by original owner) that the solar and altenator would charge both batteries, I hear the charging relay switching(loud click) often, so its doing something.
"Or do you plan to manually combine?",
as I am slowly learning more about this system from these responses, I am hoping that the relay will require a manual change to send power to the starting battery when needed to keep from blowing my 150 amp fuses on both battery pos posts. I dont know enough yet to plan on anything in this system.
what does the "backward wiring" mean,
thanks for responding
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
