blueh20
Oct 29, 2018Explorer
littlebill, thanks for chiming in, I just learned ALOT about my charging relay in your post. And hope you can teach me some more.
"realistically you should never have a dead starter battery, that said if you do, i would recommend waiting a minute or so in override before attempting the start"
But how would I know I had a dead starter battery before I turned the key on and tried to start the engine.
Does the relay automatically/instantly send power from the house battery to the start battery if needed, or does it require a manual switching?
"in this case using the override switch will allow the relay to connect the banks and start the motor".
What position would I turn the over ride switch too? Does that "override" switching include pushing the button "down"?
In using the over ride switch, would I just let the batteries coexist for 15 minutes or so, then turn the switch off so to disconnect the two batteries before starting so I dont blow my 150 amp fuses? OR try and start the vehicle while they are both bonded together?
thanks
thanks
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
