blueh20
Oct 29, 2018Explorer
Not only can I turn the relay off I also put a disconnect switch right at my house battery which is 10" from the relay and two feet from the battery..
So maybe I ought to just leave the two systems separated all the time so as to not stress out my alternator/regulator and that way I can figure out if the solar is up to the task of keeping house appliances going on its own, I only have:
led lights=1amp draw
dual usb charger= says "fast charge 4.8amp"
arb fridge=says 1.5 amps per hour(which is average rating)
adding flojet water pump=says 7.5 amps at full pressure, which will have very slight intermittent use.
and then only use the ACR if I ever get a dead starter battery? if this is the case it doesnt seem worth it to have those 2/0 battery cables all stretched through the frame and worrying about it shorting out or destroying the alt..thoughts
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
